#1 2011-09-24 14:48
titi
Rename Email .eml
Hello everyone,
Renamer is a great software!  smile
I would like to rename a large number of email as .eml
I have a problem with some files such as the following.
The file is: 1C457103-00000011.eml http://siffic.free.fr/1C457103-00000011.eml
I wish I had as a result: 20100613 florent.hirel@31000emploi.com innovha-france@orange.fr Candidature à votre annonce depuis 31000EMPLOI.com
In short: "date sent" "From" "To" "Subject"
How to do?
Thank you in advance,
Titi
#2 2011-09-24 17:27
Re: Rename Email .eml
Hi Titi and welcome to the community.
Titi> In short: "date sent" "From" "To" "Subject"
Titi> How to do?
I don't know really but you can check this links:
Our wiki about Insert rule with "Insert meta tag" option
and the list of meta tags to export including:
:Email_DateSent: or :Outlook_DateSent:
:Email_Sender: or :Outlook_Sender:
:Email_Subject: or :Outlook_Subject:
But "Email_From" seams to be missed from the possibilities.
You can also search the forum for "eml" to read more about email meta tags.
Perhaps we can use an PascalScript to parse the eml file for
Reply-To:
To:
lines and extract the TO email address?
#3 2011-09-24 18:03
titi
Thank you very much for the quick response,  big_smile
Following your suggestions, I created the following rules:  cool
[Rule0] ID=Delete Config=FROM:1;UNTIL:2;FROMPOSITION:1;UNTILCOUNT:1;FROMDELIMITER:;UNTILDELIMITER:;RIGHTTOLEFT:0;SKIPEXTENSION:1;LEAVEDELIMITER:0 Marked=1
[Rule1] ID=Insert Config=TEXT:%3AEmail%5FDateSent%3A+SUBJECT+%3AEmail%5FSubject%3A+TO+%3AEmail%5FSender%3A;WHERE:1;POSITION:1;INSERTAFTERTEXT:;INSERTBEFORETEXT:;RIGHTTOLEFT:0;SKIPEXTENSION:1 Marked=1
[Rule2] ID=Remove Config=TEXT:%3D%3Fiso%2D8859%2D1%3FQ%3F;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule3] ID=Remove Config=TEXT:%3F%3D;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule4] ID=Delete Config=FROM:1;UNTIL:1;FROMPOSITION:5;UNTILCOUNT:1;FROMDELIMITER:;UNTILDELIMITER:;RIGHTTOLEFT:0;SKIPEXTENSION:1;LEAVEDELIMITER:0 Marked=1
[Rule5] ID=Delete Config=FROM:1;UNTIL:1;FROMPOSITION:7;UNTILCOUNT:1;FROMDELIMITER:;UNTILDELIMITER:;RIGHTTOLEFT:0;SKIPEXTENSION:1;LEAVEDELIMITER:0 Marked=1
[Rule6] ID=Delete Config=FROM:1;UNTIL:1;FROMPOSITION:9;UNTILCOUNT:9;FROMDELIMITER:;UNTILDELIMITER:;RIGHTTOLEFT:0;SKIPEXTENSION:1;LEAVEDELIMITER:0 Marked=1
[Rule7] ID=Delete Config=FROM:1;UNTIL:1;FROMPOSITION:1;UNTILCOUNT:2;FROMDELIMITER:;UNTILDELIMITER:;RIGHTTOLEFT:0;SKIPEXTENSION:1;LEAVEDELIMITER:0 Marked=1
[Rule8] ID=Remove Config=TEXT:%3D%3FUTF%2D8%3FQ%3F;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule9] ID=Remove Config=TEXT:%5C;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule10] ID=Remove Config=TEXT:%2F;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule11] ID=Remove Config=TEXT:%3A;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule12] ID=Remove Config=TEXT:%2A;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule13] ID=Remove Config=TEXT:%3F;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule14] ID=Remove Config=TEXT:%22;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule15] ID=Remove Config=TEXT:%3C;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule16] ID=Remove Config=TEXT:%3E;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
[Rule17] ID=Remove Config=TEXT:%7C;WHICH:3;SKIPEXTENSION:1;CASESENSITIVE:0;USEWILDCARDS:0 Marked=1
I have two problems:
- I can not get the text TO
- For email I gave an example or the "outlook_objet" or the "email_objet" do the right object recupéere
This gives:
100611 SUBJECT =UTF-8BQ2FuZGlkYXR1cmUgw6Agdm90cmUgYW5ub25jZSBkZXB1aXMgMzEwMDBFTVBM  =UTF-8BT0kuY29t TO florent.hirel@31000emploi.com.eml
What do you think I can do?  roll
Thanks for all
PS : If you want i can translate it in French ?
#4 2011-09-24 19:44
