#1 2011-10-03 20:57
Selecting files in a horizontally scrolled view
I've noticed something strange when clicking on columns that are not completely visible because of being at the edge of the window. In previous builds when you clicked on them it used to move horizontal scroll to show the full column. Now it's unable to do that. When you click on the half-column (both sides of the window), the scroll comes back always to the start.
I'm not really a fan of that feature, but the most bothering thing is that because of that movement it fails to do CTRL+Click on the elements. (Now I know that clicking in other column it will work, but when you don't it's not nice.)
#2 2011-10-03 23:44
Re: Selecting files in a horizontally scrolled view
This was caused by the updated component for the files table. It seems that the selection of feature defaults was changed.
Try the latest dev version, it should fix the problem.
P.S. For those who are using the official 5.60 release, you can still use CTRL + Right-Click or CTRL + Click-and-Drag selection methods.
#3 2011-10-04 08:01
Thanks, it's working now. smile
#4 2011-10-05 07:22
Ouch, something went wrong...
Now when pressing the Arrow keys (or Home, End, Page Up and Page Down) it doesn't move the vertical scroll either  hmm
roll
#5 2011-10-06 22:57
OK, I have reverted back to the previous configuration of options. This looks like a bug in the component and I am reporting it to the author.
The problem occurs only when the right most column is partially hidden and selection is performed on the right most column. For now, use either the neighbouring column for selection or scroll to the most right side so that the most right column is fully visible before selecting.
To track the progress of this issue:
http://code.google.com/p/virtual-treevi … ail?id=241
#6 2011-10-07 08:01
Ok, let's wait wink
