Q: How can i add leading zeros to pad all numbers the same length?
Dropping the original numbers and use serialize rule to add new numbers is no option
because the numbers are not in an sequence:
1.txt 001.txt
6.txt 006.txt
10.txt 010.txt
11.txt 011.txt
12.txt 012.txt
99.txt 099.txt
123.txt 123.txt
145.txt 145.txtA: one way is to use an PascalScript >>> http://www.den4b.com/forum/viewtopic.php?id=26
But if the names are that simple as with your example
you can also do this two steps:
1) Insert: Insert "0000" as Prefix (skip extension)
Just add as many zeros as you like. Just enough to pad the shortest file name to the wanted length,
or use many more, it doesn't matter.
This will get you:
1.txt 00001.txt
10.txt 000010.txt
99.txt 000099.txt
145.txt 0000145.txt 2) Delete: Delete from Position 4 until the End (right-to-left) (skip extension)
Use the delete rule and delete all from the 4th position from the right (from the back/from the end) to the begin.
This will get you:
1.txt 001.txt
10.txt 010.txt
99.txt 099.txt
145.txt 145.txtRead the *WIKI* for HELP + MANUAL + Tips&Tricks.
If there are other signs then just an number in the file name, use an PascalScript like this.
Word 1 Word2.txt
Word 4 6.txt
10.txt
Word Word 11 Word.txt
12Word.txt
Word Word 13.txt
Word 20.txt
Word Word Word 21.txt
Word 33Word.txt
Word 99 2011.txt
Word 123.txt
7Word145.txt
Word 00001 Word2.txt
Word 00004 6.txt
00010.txt
Word Word 00011 Word.txt
00012Word.txt
Word Word 00013.txt
Word 00020.txt
Word Word Word 00021.txt
Word 00033Word.txt
Word 00099 2011.txt
Word 00123.txt
00007Word145.txt
USE:
SubPatterns: TStringsArray;
SubPatNum1: WideString;
PAD_TO_LENGTH = 5;
Begin
//This RegEx will match first digit in file name, between signs or not:
SubPatterns:=SubMatchesRegEx(WideExtractBaseName(FileName),'(.*?)(\d+)(.*)',false);
//If you have to match other digits then just the first found, you have to adjust the regex used.
//The code.Don't modify:
If Length(SubPatterns) <=0 then exit;
SubPatNum1 := SubPatterns[1];
while Length(SubPatNum1) < PAD_TO_LENGTH Do
SubPatNum1 := '0' + SubPatNum1;
FileName := SubPatterns[0] + SubPatNum1 + SubPatterns[2]
End.Read the *WIKI* for HELP + MANUAL + Tips&Tricks.
