#1 2011-12-30 21:54
Fiorello
Drag & drop within the file list doesn't work any longer
Hi!
Drag & drop of a single line to move an entry up or down within the file list of ReNamer doesn't work any longer as it was possible in former versions. Could you make it possible again???
Best wishes,
Fiorello
#2 2011-12-31 01:23
Re: Drag & drop within the file list doesn't work any longer
Confirmed
Meanwhile: Select file/s, and Ctrl+ArrowUp or Ctrl+ArrowDown
#3 2012-03-02 22:04
Fiorello
Are you working on it??? It is very annoying to sort a list of e.g. 50 mp3 files by keyboard shortcuts mad. Drag & Drop with the mouse makes it very easy and quick.
Now I reinstalled an old version of Renamer (5.50) which allows drag & drop within the file list.
Best wishes,
Fiorello
#4 2012-03-04 01:02
Previous update of Virtual Treeview component to v4.8.7 caused the drag & drop feature of the files table to stop working. As a workaround, SimpleDrawSelection flag had to be disabled and now drawing a selection with the mouse will work only on if the State column is in the drawn rectangle.
This issue should be fixed now. Please try the latest development version.
#5 2012-03-04 17:58
Fiorello
Wow, it works fine now  smile Very excellent applicaton!!! Many thanks, den4b!
