#1 2006-11-10 22:16
fjord
ReNamer 4.20 Win Explorer File menu
Hi Denis
Thanks for the new version. Just installed 4.20, and enabled the folder and files context menu options to see how they work. In Windows Explorer (Win XP SP2, Danish), with the Folders panel displayed, the File menu shows a ReNamer item just above the Exit item, with the following menu items on my PC. These are all context menu items for various file types, but these are mostly not relevant as items on a ReNamer submenu.   [English equivalent shown in brackets]  This menu is not shown when Folders panel is not shown.
    Stifinder  [Explorer]
    Åbn   [Open]
    Browse with IrfanView
    Søg...  [Search]
    Mp3tag
    Add to ReNamer
    Add to Winamp's Bookmark list
    Enqueue in Winamp
    Play in Winamp
    7-Zip
    Upload using CuteFTP Pro
    SnagIt
    NOD32 antivirus system
    Send til
    Klip
    Kopier
    Opret genvej
    Slet  [Delete]
    Egenskaber  [Properties]
Perhaps not what you intended in the context of Win Explorer File menu?
Below a screenshot of Windows Explorer with the File > ReNamer submenu open:
#2 2006-11-11 16:53
Re: ReNamer 4.20 Win Explorer File menu
Hi fjord!
You have misunderstood that menu! It is a Windows feature, when you are in the explorer mode (with folders tree), you automatically get an extra submenu in the File menu, which represents a context menu of a Folder that you have currently selected (which you are browsing). So if you select a folder called "Some-Folder-Name" - you will get a submenu just above the Close item, called "Some-Folder-Name" instead of "ReNamer". Because you were in the "ReNamer" folder - you get a "ReNamer" submenu. Have a look at the screenshot, maybe it will become more clear...
No bug in here wink
#3 2006-11-12 17:02
fjord
Well, I'll be darned. That's a new one for me! It's great to learn something new every day. big_smile
Thanks. Best regards!
#4 2006-11-12 20:26
It was a new one for me as well, and it got me there for a moment!  wink
