#1 2012-06-21 15:57
April
Putting a space before a capital letter
Hello again!
You were all so nice & helpful last time, I decided to bug you again smile
A common problem I'm running into is files with names like this:
"EdwinArlingtonRobinson-Merlin"
Is there a way to insert a space before each capital letter?  I've been doing them manually, and it takes FOREVER.
Thanks so much -  you guys are awesome smile
#2 2012-06-21 19:50
Re: Putting a space before a capital letter
Hi April, we have thought about such your issue already beforehand,
Edwin Arlington Robinson-Merlin
please take an look at >> http://www.den4b.com/wiki/ReNamer:Rules:CleanUp
For your special case "Robinson-Merlin" you can use an additional RegEx Rule:
Edwin Arlington Robinson - Merlin
1) CleanUp: Insert space in front of capitals, Fix spaces (skip extension)
2) RegEx: Replace expression "([a-z])-([A-Z])" with "$1 - $2" (case-sensitive) (skip extension)
I guess i should not take you that exactly with
"Is there a way to insert a space before each capital letter?"
but not before an hyphen ? ;-)
If  surely, use:
2) RegEx: Replace expression "([a-z])-([A-Z])" with "$1- $2" (case-sensitive) (skip extension)
to get "Edwin Arlington Robinson- Merlin" in real.
BTW: Instead of one CleanUp plus one RegEx Rule you can also use two RegEx Rules like:
1) RegEx: Replace expression "([a-z])([A-Z])" with "$1 $2" (case-sensitive) (skip extension)
HTH? big_smile
(Thanks to Denis for the "Export rules to clipboard" feature!)
#3 2012-06-21 19:53
April
Stefan,
Will you marry me?
(Just kidding, but thanks again!)
April
#4 2015-09-29 16:05
lanceru
Stefan your method worked flawslessly.
I used the following rule to insert a hypen before every Capitalized word except the first.
([a-z])([A-Z])
$1_$2
Checkbox: Skip extension, Case sensitive
I have 3questions though.
What if I only want to add a hyphen, before only the 2nd capitalized word?
Or,
At only the 3rd capitalized word?
Or,
For the 2nd and 3rd capitalized words (specify range)?
I have a file named:
JimCanson_DepartmentManufacture,
and then transform it to:
Jim_Canson_DepartmentManfacture, not Jim_Canson_Department_Manufacture
#5 2015-10-05 19:33
WARNING: DO NOT POST YOUR QUESTIONS IN TOPICS THAT ARE YEARS OLD! START A NEW THREAD!
Your question has been answered in a different thread.
