#1 2012-08-22 15:51
EHCanadian
Input box to paste path without having to navigate
I would like to see a option below the navigation to input/paste a path rather then
having to navigate to the desired location. While this may seem like a lazy user request...
Well sometimes I have things on other drives and its a pain to navigate or shift the files to the last
working directory where I had used it last smile
Anyhow... Groovy product. Thx for making it
#2 2012-08-23 22:02
Re: Input box to paste path without having to navigate
You must be talking about the Browse dialog. In which case, right-click anywhere in the tree and select option "Go To Folder". There you will be able to paste your path and the Browse dialog will navigate to it. Alternatively, just drag & drop the folder to ReNamer.
The Browse dialog supports selection of multiple folders (holding down CTRL key), hence, single path field is not always applicable.
P.S. Thanks for the donation.
