#1 2012-09-14 22:48
Regex223
MHT File Extension Unrecognized
When using the extension setting rule - “detect using binary signature”, it fails to recognize mhtml files. Even though the type is clearly labeled at the beginning of the HTML code.
Thanks for looking into it.
#2 2012-09-15 19:17
Re: MHT File Extension Unrecognized
I don't see how it is clearly labeled at the beginning. MHTML uses MIME format (just like emails), so there is no apparent way of distinguishing between MHTML and other MIME files.
#3 2012-09-16 16:58
Just checked, and even TrID identifies it as .EML, i.e. E-Mail message (Var. 2). As Denis said, .MHT clearly states inside that "This is a multi-part message in MIME format."
