#1 2012-12-26 14:43
iycgtptyarvg
FIXED: Renamer v5.60 b16 bug: Serialize fails with dirs with numbers
I use this script:
1. Delete - Delete from Position 1 until the End (skip extension)
2. Serialize - Serialize Incremental from 1 step 1 repeat 0 (reset index if folder changes) and pad to length 3 as prefix
3. Case - Extension lower case
For some reason (bug) it has problems with directories with numbers in them:
Example:
C:\Comicbooks\Godstorm #01\00.jpg -> 001.jpg
C:\Comicbooks\Godstorm #1\00.jpg -> 001.jpg
C:\Comicbooks\Godstorm #01\01.jpg -> 001.jpg
C:\Comicbooks\Godstorm #1\01.jpg -> 001.jpg
C:\Comicbooks\Godstorm #01\02.jpg -> 001.jpg
C:\Comicbooks\Godstorm #1\02.jpg -> 001.jpg
What it should have done:
C:\Comicbooks\Godstorm #01\01.jpg -> 002.jpg
C:\Comicbooks\Godstorm #1\01.jpg -> 002.jpg
C:\Comicbooks\Godstorm #01\02.jpg -> 003.jpg
C:\Comicbooks\Godstorm #1\02.jpg -> 003.jpg
Obviously, this doesn't work. Could you please fix this?
#2 2012-12-27 17:43
Re: FIXED: Renamer v5.60 b16 bug: Serialize fails with dirs with numbers
I don't know what would den4b say about it, but meanwhile, try sorting by path (column) before and doing the preview.
#3 2012-12-27 21:41
iycgtptyarvg
I do that already! I sort on the full path, but it sorts incorrectly.
#4 2012-12-29 10:45
Try enabling "natural sorting" in the settings and then sort by full path.
#5 2012-12-29 14:24
iycgtptyarvg
I already have natural sorting on. It's in the Settings/General tab : 'Use natural order sorting algorithm (2-3 times slower)'
Renamer doesn't see a difference between '1' and '01' and mixes them together (same for other numbers).
#6 2012-12-29 20:00
The natural sorting algorithm implies that 1 is the same as 01 and 001 and 0001.
If you disable natural sorting, then 1 will appear after 01, because comparison will be performed character by character - which is probably what you want.
Sorry don't have computer, on vacation, can't test.
#7 2012-12-29 23:02
Seems to work for me?
USE:
ReNamer 5.50+ Beta 50 >> works
ReNamer 5.60+ Beta 16 >> not tested
ReNamer 5.60+ Beta 23 >> works
UseNaturalSort=1
Otherwise nothing configured, nothing sorted.
Rules:
1) Delete: Delete from Position 1 until the End (skip extension)
2) Serialize: Serialize Incremental from 1 step 1 repeat 1
Godstorm #01
Godstorm #1
Executing result:
Information
6 file(s) successfully renamed.
2 file(s) skipped.
OK
#8 2012-12-30 13:19
I don't seem to see anything strange either, are you updating the preview (button) after changing the sorting order right?
#9 2012-12-31 10:27
iycgtptyarvg
I have ReNamer 5.60+ Beta 16.
I'll try to download a newer version and get back to check whether that helped.
Edit 1:
Where can I download a newer version?
#10 2012-12-31 12:14
How about "go to the homepage" and watch out for something like "Downloads"?
