#1 2013-01-22 16:12
tomyan112
Add support to music file tags (ID3 APE Meta Tags)
Is there a possibility that you can add support to the three types of tag, ID3v1, ID3v2 and APE?
#2 2013-01-22 20:26
Re: Add support to music file tags (ID3 APE Meta Tags)
Please look at the Meta Tags available from the Insert and Replace rules, e.g.: ID3_Artist, ID3_Title, etc.
#3 2013-01-23 18:02
tomyan112
You can only replace or insert the tags to the file name in currently function.
What I am trying to say is that edit the tag just like edit normal file name.
Example
http://s9.postimage.org/spxgmgbjx/Untitled_5.jpg
#4 2013-01-23 20:00
This tool ReNamer is to modify file names.
To modify file contents like meta data as ID3 tags there are many other tools available.
E.g. TagScanner or MP3Tag. For me mostly Media Tagger is enough. Before i used MP3 Book Helper too.
All are free and portable.
