#1 2013-03-14 11:55
Kilmatead
One wonders if Beta 30 is Playing Fare for a Pun...
It could be a pun, considering the context of mercantile means... but... I doubt it.  It wouldn't really be fair to those who don't get puns. smile
#2 2013-03-14 22:18
Re: One wonders if Beta 30 is Playing Fare for a Pun...
I guess it was one of those late nights, when tried looks like tired, and fare like fair wink
Thanks for pointing it out. Fixed in Beta 31.
#3 2013-03-22 03:34
I also recommend that you replace "beware" with "be aware": http://www.englishwithrae.com/2011/04/1 … s-be-aware
Beware sends entirely the wrong message!
#4 2013-03-23 21:19
Andrew wrote:
I also recommend that you replace "beware" with "be aware".
Perfectly valid point, I will change it asap.
