#1 2013-03-18 15:21
ukmerlin
Import presets from old version
I was using version 5.10 from October 2007 and wanted to be able to "swap" parts of a file name around. I saw that your new version was capable of this so I have downloaded and installed it. however I have been unable to get all my previous presets to come into the new version. ~ S
#2 2013-03-18 15:52
Re: Import presets from old version
The presets are compatible, so you just need to make sure that they are in the correct location.
Presets are normally stored in the installation folder, in "Presets" subfolder. Copy all presets to the new installation path.
If you need more help with that, please provide full paths of both old and new installations of ReNamer.
