#1 2013-04-06 19:50
Dirk
How to start with special preset?
How can I start ReNamer with a special preset already loaded so that you can rename with it? E.g. double clicking the rnp file doesn't load the preset, just adds it to the renaming list.
Where can I set to receive e-mail notifacations on new replies here?
#2 2013-04-06 19:56
Re: How to start with special preset?
Either use a "/preset" command line parameter or use "Create Links" option from the main menu.
To subscribe to a topic click on the "Subscribe to this topic" link at the bottom.
#3 2013-04-06 20:13
Dirk
Many thanks,
Ah, I had missed it, the "Create Links" option.
Yes, the bottom at the bottom I had found and used, I meant, somewhere in the profile or so the option to suscribe to each new post by default.
Thanks again.
#4 2013-04-09 11:08
Unfortunately there is no such option implemented in this forum.
#5 2013-04-09 12:25
Dirk
Ah, OK, I understand, so just not forget to check the option each time below the new posting.
Thank you.
