#1 2013-10-13 15:08
fjord
Updating preset when there are 5 existing presets (Lite v5.72)
I've updated to 5.72 and ordered a pro license. I'm very happy to support continued development of this excellent program.
Until the license arrives, I'm running Lite, limited to 5 presets. (I cleaned out old presets, keeping only 5 currently used presets.)
I want to modify one of the 5 existing presets, but when I try to Save as, I get the error message "This version is limited to a maximum of 5 presets."  I don't get a chance to save it as one of the existing 5 presets. By deleting one preset, so I only have 4, I can then get to the Save preset dialog and save the modified preset under an existing preset name.
Consider enforcing the 5-preset limit when "Save" is pressed in the "Save preset" dialog, rather than when the "Save as" command is entered. This will permit saving a modified version of an existing preset, when there are 5 existing presets. The error message should suggest to delete one or more existing presets in "Manage presets" before saving a new preset.
#2 2013-10-14 08:38
ozzii
Re: Updating preset when there are 5 existing presets (Lite v5.72)
Try to do a 'preset' / 'rescan'
_________________
#3 2013-10-17 08:50
fjord
My ReNamer has upgraded itself to Pro (license purchased 5 days ago). Thanks for your suggestion ozzii, but I can't try it - I can now have unlimited presets. It's a moot point for me now.
#4 2013-10-17 10:34
@fjord
Thanks for reporting this issue. It will be fixed asap.
#5 2013-10-17 19:24
This issue has been addressed by an additional "Save" option - for directly saving the currently loaded preset. "Save As" option will maintain an assumption that the preset will be saved as new.
This affects both ReNamer and Shutter.
