#1 2013-12-14 13:57
nichtsooft
My own little RenameScript
Hi there!
I haven't done Pascal since I was in sec. modern school, but I gave it a shot
--> It didn't work and that's why I end up here! sad
Basically it's about cleaning up folders containing audio -and associated other files...
I got a FolderStructure like "X:\genre\subgenre\band - album - year - format\filename" and if some filenames hit some criteria I'm tryn' to rename them as you can see in the script:
VAR
	Folders, Parts: TStringsArray;
	ThisFolderName, Band, Album, ThisFileName, NewFileName: WideString;
	PathDepth, FolderParts : Integer;
BEGIN
	Folders		:= WideSplitString(FilePath,'\');
	PathDepth	:= Length(Folders);
	IF PathDepth > 1 THEN
	BEGIN
		ThisFolderName	:= Folders[PathDepth-1];
		Parts			:= WideSplitString(ThisFolderName,' - ');
		FolderParts		:= Length(Parts);
		IF FolderParts > 1 THEN
		BEGIN
			Band		:= Parts[0];
			Album		:= Parts[1];
			ThisFileName:= WideExtractFileName(FilePath);
			IF WidePos('checker.log', ThisFileName) > 0 THEN
				FileName:= Band + Album + ' - Audiochecker.log';
			ELSE IF WidePos('LAC.log', ThisFileName) > 0 THEN
				FileName:= Band + Album + ' - LAC.log';
			ELSE IF WidePos('_r.jpg', ThisFileName) > 0 THEN
				FileName:= Band + Album + ' - Cover.jpg';
			ELSE IF WidePos('Artwork.jpg', ThisFileName) > 0 THEN
				FileName:= Band + Album + ' - Artwork.jpg';
			END;
		END;
	END;
END.
The problem is that I end up with an Error when I try to compile my script: Line 21: Error: Identifier expected
Could u please help me out with this one?
while (!$asleep) {$sheep++ }
#2 2013-12-14 16:31
Re: My own little RenameScript
Hello, and welcome!
The "Identifier expected" error is caused by a slight syntax issue around the "ELSE IF" keywords.
The statement that precedes "ELSE" keyword must not have a terminating semicolon ";". Below are few examples:
  • IF condition THEN statement;
  • IF condition THEN statement ELSE statement;
  • IF condition THEN statement ELSE IF condition THEN statement;
  • IF condition THEN BEGIN statement; statement; END;
  • IF condition THEN BEGIN statement; statement; END ELSE statement;
In your script, this part...
END;
Need to be as follows...
All I did was removed terminating semicolons ";" before "ELSE" and removed "END;" as it is not needed there.
Also, this resource might come in handy: http://www.den4b.com/wiki/ReNamer:Pascal_Script
#3 2013-12-14 17:54
nichtsooft
Aaaahhhh....
Cheers m8. That helped me a lot!
So here's the final script if anyone should need it in the future:
VAR
	ThisFolderName, Band, Album, ThisFileName: WideString;
BEGIN
	ThisFolderName	:= WideExtractFileName(WideExtractFileDir(FilePath));
	BEGIN
		Band		:= Parts[0];
		Album		:= Parts[1];
		IF WidePos('audiochecker.log', ThisFileName) > 0 THEN
			FileName:= Band + ' - ' + Album + ' - Audiochecker.log'
			FileName:= Band + ' - ' + Album + ' - LAC.log'
			FileName:= Band + ' - ' + Album + ' - Cover.jpg'
			FileName:= Band + ' - ' + Album + ' - Artwork.jpg'
		ELSE IF WidePos('Invoice', ThisFileName) > 0 THEN
			FileName:= Band + ' - ' + Album + ' - ' + ThisFileName;
	END;
END.
