I'm back again to ask for help ![]()
How can I remove (delete) a space " " at the end of a filename, if there is one?
Example:
ABBA - Fernando.mp3
ABBA - Thank You For The Music .mp3
How can I remove that space in the second filename, at the end, just before the file extension? And remove it only if there is one?
Thank you very much once again.
Hi and welcome.
Denis has already thought to you, see:
CleanUp Rule >> Fix spaces
Replace multiple consecutive spaces with a single space.
It also removes spaces from the beginning and the end of the filename:
http://www.den4b.com/wiki/ReNamer:Rules:CleanUp
That should do the trick easily
Thanks a lot Stefan, it worked perfectly! ![]()
