#1 2014-05-09 16:37
erebus
Arguments problem with presets
Hello
I have a problem with the arguments and presets
i use
strokeit for gesture mouse and RocketDock
and both i create a shortcut like this:
target        :"C:\Program Files (x86)\renamer\ReNamer.exe"
arguments  :"ReNamer.exe" /preset "Series 01" "D:\Download\[0Series]"
its open renamer in the good folder but no presets.
When i execute with run command: "C:\Program Files (x86)\renamer\ReNamer.exe" /preset "Series 01" "D:\Download\[0Series]" its work perfect
what the problem ?
i understand nothing
thanks
Best regards
#2 2014-05-10 10:15
Re: Arguments problem with presets
You should not have "ReNamer.exe" in the arguments, try removing it, like so:
Target:     "C:\Program Files (x86)\renamer\ReNamer.exe"
Arguments:  /preset "Series 01" "D:\Download\[0Series]"
ReNamer expects "/preset" to be the first argument.
#3 2014-05-10 11:42
erebus
OK
thanks its work perfect
thank you
