#1 2014-05-20 07:33
PascalScript - Hide console windows
ExecConsoleApp() desperately needs a intWindowStyle param like VBS' Run() method has so console apps can be executed (and their outputs captured) without irritating windows popping up every time!
It need not be as elaborate as intWindowStyle but even a Boolean true/false to show/hide the window would be fantastic.
#2 2014-05-20 16:54
Re: PascalScript - Hide console windows
Could this be related with a similar problem I have with exiftool? I talk about it here.
#3 2014-05-20 23:50
@SafetyCar: Of course, that is a console app too so if this issue is solved you'll not have to see an irritating window for ExifTool pop up for every single file that is processed, every time you preview or rename. hmm
#4 2014-05-21 16:56
This should be addressed in the latest development version.
  • ExecConsoleApp function now forces the external process to be executed in the hidden mode (SW_HIDE flag).
  • ExecuteProgramShow function, similar to ExecuteProgram but it also allows to control how the window is to be shown.
More details on the wiki:
ReNamer:Pascal_Script:Functions#Process_Execution
#5 2014-05-27 01:40
Haven't tested both but I assume they work as advertised. Was just hoping for an extra param for ExecConsoleApp() but the addition of ExecuteProgramShow() is pure icing on the cake! big_smile
#6 2014-06-04 14:00
Andrew wrote:
Was just hoping for an extra param for ExecConsoleApp()...
I've decided not to bother with additional parameters for ExecConsoleApp because output is redirected to Output variable and input stream is closed to prevent console application from waiting for user input, so the console window will always be blank (no input, no output).
