#1 2007-04-08 13:47
justsmile
Renamer: Moving parts of filename
Hello!
First of all: GREAT WORK, your software is really helpful!
My idea is:
Can you implement a function that would take x characters from position y of the filename and move them z letters to left, right, end, etc. ?
For example I have files like
20070102log.txt
20050405log.txt
20061105log.txt
Then I use this function to
take 8 letters from position 1
move them to
position 1 from right side.
After clicking rename, I will get
log20070102.txt
log20050405.txt
log20061105.txt
Would really help me a lot!
Thanks!
#2 2007-04-12 14:18
Re: Renamer: Moving parts of filename
Sorry, I'm away for few weeks and have almost no internet connection over here...
Your problem is easily solvable with the RegEx rule, with these parameters:
Expression: (\d+)(.*)
Replace: $2$1
Skip Extension: Yes
Or, you can use pascal script called "Move filename portion" that works exactly as your idea above.
Just change the values of these constants at the top of that script, after you load it:
  MOVE_START = 5;   // beginning of the movable portion
  MOVE_LENGTH = 3; // length of the movable portion
  MOVE_TO = 3;        // new position for the portion
