#1 2014-09-04 13:24
essereumano
Event triggered and not work
Hi, I use shutter on my pc with xp sp3 and I've added two same events, at 12 am and at 7 pm my pc must shut down, but when I see my pc is already powered and the event status is "triggered". With the older version all is ok, the pc shut down correctly but I need to use two events and with the older app I cant'.
What I wrong do?
Thanks in advance for reply.
#2 2014-09-18 10:18
Re: Event triggered and not work
What I wrong do?
What did you set the "Logic" option to?
If it is set to "ALL", it will mean that all events must be triggered to allow execution of specified actions. Please make sure it is set to "OR", which will monitor all events independently and execute actions if any of the tracked events are triggered.
If it is still not working, please save your configuration as a preset and post it here.
