#1 2014-11-21 07:22
Display
Drag Select?
I used to be able to drag select files/folders/names from the lower half of the ReNamer interface. This was really handy for selections!
I'm not sure when this stopped working, but now using the latest Beta (Pro), I can no longer drag select?
Is this by intention or is it a bug from the development/updates?
Thanks for any info!
#2 2014-11-22 22:04
Re: Drag Select?
This feature was disabled intentionally in ReNamer 6.0. This option is not fully working in the current version of the VirtualTreeview component, which is used for the files table.
It can be brought back as soon as it's implemented/fixed by the component maintainers.
In the meantime, you can hold SHIFT or CTRL keys to extend the selection.
#3 2014-11-23 03:54
Display
Re: Drag Select?
Aha, gotcha, yea that makes sense. Well I'm glad it was intentional rather than an oversight.
I look forward to its return, but for now the modifier keys are my best friends smile
Cheers!
