#1 2015-04-07 08:23
crane
Replace underscore between numbers with dots
Example:
"file_name_v20_6_5_some_text.txt" to "file_name_v20.6.5_some_text.txt"
I tried the following regex replace but it fails:
(\d)_(\d)
$1.$2
#2 2015-04-07 18:13
Re: Replace underscore between numbers with dots
Hi crane  and welcome.
This is because the regex engine didn't find another "(\d)_(\d)" match after the "20_6", there only is "_5_some_text.txt" remaining.
This would be different for a file name like "file_name_v20_6_some_6_5_text.txt"
The simplest solution for you is to duplicate the rule (right click the rule and chose 'Duplicate Rule')
One is for the  "20_6" and the other for the "6_5" part in a second pass.
1) RegEx: Replace expression "(\d)_(\d)" with "$1.$2" (skip extension)
2) RegEx: Replace expression "(\d)_(\d)" with "$1.$2" (skip extension)
Another solution, depending on the file names, would this single RegEx rule:
1) RegEx: Replace expression "_(\d)" with ".$1" (skip extension)
#3 2015-04-07 23:01
Also, this handy PascalScript will do the job.
It will work for any number of sets of digits, no need to duplicate the rule.
  I: Integer;
  for I := 2 to Length(FileName) - 1 do
    if FileName[i] = '_' then
      if IsWideCharDigit(FileName[I-1]) then
        if IsWideCharDigit(FileName[I+1]) then
          FileName[i] := '.';
#4 2015-04-08 05:07
crane
Pascal script is working fine.
Thanks smile
