#1 2015-04-25 12:02
carolinne
Editing all the rules having a same word in it at once
Hi
How I can do the following:
I wanted to create a preset with a set of rules applying to a certain word
f.e. 2015 or spaghetti05, anything really
and then to use that same preset for other words
and I was planning to edit the .rnp file
and replace all spaghetti05 with tomatosoup at once
(I was able to do that in the past)
But now I can't make it work. Or is there a better way to do this?
Any help appreciated.
Thank you in advance
#2 2015-04-25 12:27
Re: Editing all the rules having a same word in it at once
There is no supported way to edit multiple rules at once. So editing .rnp files directly is probably your best bet.
What kind of problems do you experience? Why did it work in the past and not working now, maybe we could help?
#3 2015-04-25 12:49
carolinne
I'm sorry. I've just installed the newer vn 6.01 and there it works.
Probably instead of installing the newest vn, I mistakenly installed some older one.
To end with a smile:
I had been doing Tech Support for Hewlett-Packard's DeskJet division for about a month when I had a customer call with a problem I just couldn't solve. She could not print yellow. All the other colors would print fine, which truly baffled me because the only true colors are cyan, magenta, and yellow. For instance, green is a combination of cyan and yellow -- but green printed fine. Every color of the rainbow printed fine except for yellow. I had the customer change ink cartridges. I had the customer delete and reinstall the drivers. Nothing worked. I asked my co-workers for help; they offered no new ideas. After over two hours of troubleshooting, I was about to tell the customer to send the printer in to us for repair when she asked quietly, "Should I try printing on a piece of white paper instead of this yellow construction paper?"
#4 2015-04-25 21:58
I'm glad you got it working.
That's pretty funny! smile
