#1 2015-05-03 15:45
Gerhard87
Inverting Filter mask
I want to automatize some renaming tasks.
So I want to use the command line options.
I already built a preset renaming the files.
Folder example:
Renaming shall work like this:
remove %20
remove beta
remove alpha
add in front of the filename test_
result (not sorted):
this works so far if I manually insert the files.
The problem is selecting the right files when using the command line with only the folder.
I can use a filter to select all test_* but I can't filter inverse.
I just want to process all files not beginning with test_
Same with thumbs.db (workaround is making it hidden)
So I'm looking for a filter option to not select files by mask.
Thank you - great software by the way.
#2 2015-05-06 13:50
Re: Inverting Filter mask
That's a good suggestion, thanks.
It's now on the list for future implementation.
#3 2015-05-09 21:49
Exclusion filter masks have been added in ReNamer 6.2.0.1 Beta.
#4 2015-05-09 21:59
Gerhard87
This was really fast!
And it works wink
Thank you very much, I'll definitely renew my license when it expires.
P.S.: I thoutght future implementation means weeks to months... I was wrong smile
#5 2015-05-09 22:23
Gerhard87 wrote:
I thought future implementation means weeks to months... I was wrong smile
For some ideas it could even take years. Complexity, implementation time, usefulness, etc - they all affect the priority of new features.
In this case the odds worked in your favor! wink
