#1 2015-08-18 12:33
voody
Hooker 3.3 stops working after 30min - 1hour
I'm using Hooker 3.3 Lite. I have problem - program works fine 30min - 1hour and next in log file I see "[Deattached from process]". After this log Hooker send only <CLIPBOARD></CLIPBOARD> logs.
Someone know hot to fix this??
Thanks! smile
#2 2015-08-18 12:59
Re: Hooker 3.3 stops working after 30min - 1hour
Please provide more information about your system:
  1. Version of Windows
  2. Anti-virus
  3. User Account Control (UAC) settings
#3 2015-08-18 14:55
voody
Windows 7 Professional Service Pack 1x64
Kaspersky Endpoint Scurity 10 for Windows 10.2.1.23
UAC - Second from top
UAC
#4 2015-08-19 21:54
Have you noticed anything in common when it happens, for example, it stops when you start or stop a certain application? Has it worked fine before and started having issues only recently?
I presume you have added an exception for Hooker in Kaspersky Endpoint Security? Try temporarily disabling it altogether.
Also try using an older version of Hooker 3.0.
