#1 2016-02-02 18:49
ajfudge
What happened to Turn Off Monitor quick action?
Hi. I upgraded from v3.1 to v3.7
In v3.1, the "Turn Off Monitor" quick action is available when right-clicking on the program's tray icon.
What happened to this? I'm asking because this is my mainly used feature of your program.
Here's v3.7 without "Turn Off Monitor" quick action:
Turn Off Monitor quick action missing in Shutter
Shutter removed Turn Off Monitor quick action
#2 2016-02-03 09:28
Re: What happened to Turn Off Monitor quick action?
"Turn Off Monitor" action got eventually converted to "Monitor" action with options to either turn off or turn on the display. As a result, it was removed from the list of quick actions because it now had additional options.
At the moment, you can save the "Monitor" action in a preset without any events and create a shortcut to that preset for a quick execution right from your desktop.
It should be brought back as a quick action, I agree.
#3 2016-02-03 10:46
ajfudge
Thank you. Please bring it back.
The suggestion you gave, while good, only adds clutter to my desktop.
The tray icon is simply more accessible, I think. smile
#4 2016-02-03 22:37
#5 2016-02-04 06:28
ajfudge
Thank you! Thank you! big_smile
