#1 2016-02-17 08:17
bobyang
Blurry font in High DPI
I found the fonts are blurry in windows 8.1 and windows 10. It will be great if you can do a small modification. thanks!
http://crsouza.com/2015/04/how-to-fix-b … -settings/
#2 2016-02-17 15:16
Re: Blurry font in High DPI
If the DPI awareness is enabled in ReNamer, application will be crisp but will appear significantly smaller because there is no built-in automatic form scaling in Lazarus IDE like in Visual Studio (from your link).
It is planned for future, but it's not high in priorities list.
In the meantime, here is a workaround to disable blurry scaling:
  1. Right-click on the application
  2. Open "Properties" menu
  3. Open "Compatibility" tab
  4. Enable "Disable display scaling on high DPI setting" option
