#1 2016-02-21 18:56
Elektro
RegEx Named Group example?
Hi!
Please den4b could you explain us how to use named groups for regular expressions in the script editor?.
I was looking for the proper syntax but I didn't found it, also I'm not sure if the scripts runs under pascal-script limitations, or Delphi/object-pascal limitations, could you clarify this too?.
How I could name a simple group like this?:
str        := "Hello World"
rgxPattern := '(Hello)'
rgxReplace := '$1 World'
Thankyou.
#2 2016-02-23 12:49
Re: RegEx Named Group example?
Named groups are not supported by the current RegEx engine.
You can only reference groups by their index, i.e. $0, $1, $2, etc.
Reference: ReNamer:Regular_Expressions
