#1 2016-03-27 13:55
Gerhard87
Sort by "changed files first"
Is there a way to sort the files by "changed files first"?
example
random file names before:
111111
111612
111113
121114
111118
113115
111117
new file name in bold and sorted by changed files first (numerical/alphabetic ascending)
111112
111114
111115
111111
111113
111117
111118
If there is no such option, I would be very happy if it can be added wink
Another way to approach this is to add a new column e.g. renamed (yes/no)
#2 2016-03-27 16:50
Re: Sort by "changed files first"
You can use the context menu of the files table: Mark > Mark Only Changed.
Then, sort by the "State" column.
#3 2016-03-27 17:30
Gerhard87
perfect.
Thanks for the fast answer and Happy Easter!
