#1 2016-03-31 05:01
Elektro
Disable validation confirmation when loading many files?
Hi
I just would like to know whether I could disable the warning message-box that is shown when loading many files to validate.
#2 2016-04-01 15:53
Re: Disable validation confirmation when loading many files?
A hidden setting will added in v6.4.0.2 Beta to accommodate your request.
You will be able to disable validation warnings by editing "Settings.ini":
WarnValidatingTooManyFiles=0
Currently, the limit on the number of files which triggers the validation warning is set to 5000.
#3 2016-04-02 21:23
Elektro
Very useful new setting to save a little bit of time, thanks for listen us!.
