Hi
After pressing the "Rename" button, if there are items with errors in the files table, then I can't sort them by the error column. When clicking on the error column, nothing happens, items are not sorted by error message.
Tested in ReNamer 6.4.0.0
Thanks for reporting this issue.
The sorting procedure was ignoring differences between system error codes, resulting in an incorrect order of files for which a system error has occurred.
This will be fixed in 6.4.0.2 Beta.
Online
Thanks as always den4b.
Just for curiosity, one think that I still have not clear after reading your answer:
Then the error column will be sorted by error code, or alphabetically?.
The error column is not sorted alphabetically.
It is sorted by internal file status and by the system error code, if an error occurred during a renaming process.
Online
