#1 2016-06-20 05:48
Stamimail
Columns button
Consider to remove the Columns button.
Instead or in addition:
Right Click on the Column line will display the Column list.
Another suggestion:
When Folder column is displayed, Double click on a Folder Path = Open containing folder.
#2 2016-06-20 09:04
Re: Columns button
It serves as a hint to the user that additional columns are available, so it won't be removed.
This functionality already exists, check v6.5.
Double click on a row is already associated with the default action - Analyze dialog.
Instead, you can use a convenient Ctrl+Enter shortcut to open containing folder.
#3 2016-06-20 09:35
Stamimail
Re: Columns button
IMO, it is more convenient to double click on the PATH text than using the keyboard shortcut.
Perhaps, it because I used to it in Everything Search app.
#4 2016-07-08 11:39
Stamimail
Re: Columns button
I need a mouse method to view the file in explorer, after I click on Rename.
#5 2016-07-12 13:04
Re: Columns button
Right click on the file, select Shell menu, click Open containing folder.
Alternatively, use CTRL+Enter shortcut.
#6 2016-07-14 13:26
Stamimail
Re: Columns button
I am aware of these possibilities. Still, I'm looking for something more simple and easy.
