#1 2016-08-15 02:18
aip1000
PascalScript: Procedures/Functions with Optional Parameters
My understanding is that Pascal can support optional parameters, in the form:
function FilterFile(S: WideString; isEnabled: Boolean = True): WideString;
In ReNamer, I get a compiler error (semicolon expected). Can someone confirm whether or not optional parameters are supported by ReNamer's PascalScript rules?
#2 2016-08-15 10:33
Re: PascalScript: Procedures/Functions with Optional Parameters
Pascal language does support optional parameters, but unfortunately the PascalScript engine does not.
This might change in the future.
#3 2016-08-15 10:34
aip1000
Good to know; thanks for the heads up!
#4 2016-09-20 08:11
Hannibal
I hope it does change at some point.
#5 2016-09-20 09:46
We all do, but I wouldn't hold your breath while waiting for it.
Not having optional parameters is just a minor inconvenience, not a show stopper. You can always have slightly different names for functions which take fewer arguments and assume default values.
For example:
function IncrementBy(X: Integer; Y: Integer): Integer;
  Result := X + Y;
function Increment(X: Integer): Integer;
  Result := IncrementBy(X, 1); // Default of 1 is assumed
