#1 2017-02-13 13:59
yanouli
Sort pictures by hour taken and rename after
Hello
i want to realize a timelapse
i have taken 600 000 pictures in 6 months, day and night
i need to rename only all the pictures in the day between for eample 10h00min and 15h00min
i see i can class it with date exif but not with hour and date
it is possible to do that?
thanks a lot
#2 2017-02-14 10:16
Re: Sort pictures by hour taken and rename after
There several different things you can do to achieve it, but it's hard to say which fits best without knowing how exactly you are planning to rename those files. Can you provide some before and after examples?
Generally speaking, you can use EXIF date to file images hierarchically based on the individual components of date and time (day, hour, minute, etc).
You can change the default date-time format in the Settings to something like "yyyy-mm-dd\hh\nn\", basically, grouping images by date and then sub-grouping by hour and then by minute. Now you just have to insert EXIF date meta tag as a prefix to your file names. The directory structure is created automatically during a renaming operation.
So, if you have an image "image1234.jpg" taken on 2017-02-14 09:30:00, it will be renamed into directory "2017-02-14\09\30\image1234.jpg".
#3 2017-02-14 11:08
yanouli
Thanks for your quick answer
how can i insert EXIF date meta tag as a prefix to my file names?
y  try to make a rule but un order to do this but i can't do it....
thanks to help me
#4 2017-02-14 16:10
Add an Insert rule, select Prefix option, click Insert Meta Tag button, select EXIF_Date tag.
#5 2017-02-14 23:00
yanouli
tkanks!
