#1 2017-05-12 09:29
PascalScript syntax: ReplaceRegEx(TempName, MyArray[0],MyArray[1],.)
Hi Denis,
I wanted to use ReplaceRegEx() with values from an array, but stuck on the right syntax:
sLine := aLineArray[Index];
//sLine = 'feat:featuring:false:false'
aPartS := SubMatchesRegEx(sLine, '(.+):(.+):(.+):(.+)', FALSE);
// What is here the right syntax to use?
//ReplaceRegEx(const Input, wsFind, wsReplace, bCaseSensitive, bUseSubstitution $1,$2...): WideString;
TempName := ReplaceRegEx(TempName, '''+aPartS[0]+''', #44+aPartS[1]+#44, aPartS[2], aPartS[3]);
I always get "Pascal Script Compile: [Line 50] Error: Type mismatch" tongue
TIA
#2 2017-05-12 12:40
Re: PascalScript syntax: ReplaceRegEx(TempName, MyArray[0],MyArray[1],.)
It's because of the two Boolean arguments, there are no Vars expected / allowed:
Works:
TempName := ReplaceRegEx(TempName, aPartS[0], aPartS[1], false, false);
Don't work:
TempName := ReplaceRegEx(TempName, aPartS[0], aPartS[1], aPartS[2], aPartS[3]);
sP3 := false;
sP3 := 'false';
sP4 := aPartS[3];
TempName := ReplaceRegEx(TempName, aPartS[0], aPartS[1], sP3, sP4);
Here is the main part of my MultipleSearchAndReplace.pas script
where I had tried to read the four arguments from text file lines:
arrayLines := FileReadLines('MultiReplaceList.txt');
for Index:=0 to Length(arrayLines)-1 do
	strLine := arrayLines[Index];
	if strLine <> '' then
		if WideCopy(strLine, 1, 1) <> ';' then
			arrayLineParts := SubMatchesRegEx(strLine, '(.+):(.+):(.+):(.+)', FALSE);
			If (Length(arrayLineParts) = 4)Then
				TempName := ReplaceRegEx(TempName, arrayLineParts[0],arrayLineParts[1], false,false);
	Index := Index + 1;
mp3:MP4:false:false
;Old2:new2:false:false
;Old 3:New 3:false:false
e:X:false:false
a:Q:false:false
#3 2017-05-12 14:33
The signature of ReplaceRegEx function is as follows:
function ReplaceRegEx(const Input, Find, Replace: WideString; const CaseSensitive, UseSubstitution: Boolean): WideString;
Pascal Script engine does not allow optional parameters or overloaded functions, unfortunately.
Are you experiencing any issues?
#4 2017-05-12 18:59
Thanks for your support.
You ask if I have a problem?
Only that I tried to set the last two parameters dynamically, read from a text file.
But as you already wrote, that is not possible.
OK, fine. I just tried it and if it is not possible I have to find another way.
For example next I try
IF MyArray[3] = false then
        execute "RegEx(x,x,x, false
Else If
       execute "RegEx(x,x,x, true
or smtg like this. ...next week,...in my launch break...
#5 2017-05-12 20:38
Stefan wrote:
Don't work:
You can set the last 2 parameters dynamically, through variables, but variables must be of Boolean type. Strings do not get converted to Boolean type automatically, you must do the conversion.
For example:
TempName := ReplaceRegEx(TempName, aPartS[0], aPartS[1], ConvertStrToBool(aPartS[2]), ConvertStrToBool(aPartS[3]));
Where ConvertStrToBool function can be something like this:
function ConvertStrToBool(const Value: String): Boolean;
  if (Value = 'true') or (Value = '1') then
    Result := True
  else
    Result := False;
