#1 2017-08-23 04:59
tom.amitai
Replace even numbered occurrence of space
I have files with names in their names, like "Joe Blow Sam Hill Tom Jones", and I would like to change them to "Joe Blow, Sam Hill, Tom Jones".  The number of names in each file name is not the same.  Can this be done?
#2 2017-08-23 08:06
Re: Replace even numbered occurrence of space
Hi Tom,
tom.amitai wrote:
...Can this be done?
Yes, if you can provide a common pattern how to find the position to insert the comma.
Or perhaps, if you can provide a list of names to find and then we add trailing comma after each.
#3 2017-08-23 09:42
For example, considering your example, you can insert a comma after every 2 consecutive capitalized words.
Using the following Regular Expressions rule:
Replace expression "([A-Z]\w+)(\s+)([A-Z]\w+)\b(.)" with "$1$2$3,$4" (case sensitive) (skip extension)
Input:
Output:
#4 2017-08-23 18:56
tom.amitai
Input:
Output:
Thanks, that did it!  Regexes give me a headache, they look like what happens when my cat walks on the keyboard!
#5 2017-08-24 11:18
lol
