#1 2018-01-10 23:38
Stamimail
Fix spaces for FileName- with - hypens - or-other-symbols
to
FileName - with - hypens - or - other - symbols
FileName-with-hypens-or-other-symbols
New feature in CleanUp?
#2 2018-01-11 01:24
Re: Fix spaces for FileName- with - hypens - or-other-symbols
You can do this already...
to
1) Replace: Replace all "-" with " - " (skip extension)
2) Clean Up: Normalize spaces, Fix spaces (skip extension)
to
3) Replace: Replace all " - " with "-" (skip extension)
#3 2018-01-11 11:27
Stamimail
of course, I just thought it's very common task you might want to add it like an auto function somewhere in the app.
You can also add to it
to remove orphan "-" that exist before or after the text. like
-FileName- with - hypens - or-other-symbols
FileName- with - hypens - or-other-symbols -
Maybe the topic should be called:
Fix hypens for FileName- with - hypens - or-other-symbols
There is also underscores (and maybe other delimiter).
#4 2018-01-12 00:15
As you said, there are many variables and no one version that will work for all.
I believe the existing rules already provide all the necessary options to achieve any one of your scenarios.
