#1 2018-06-05 17:27
Carphunter
Only show files with names that match rename conditions
Missing something obvious.  When I dump a directory full of files in, and only need to see which files will actually be renamed as they match my rules... how do i filter out all the files that won't be changed?
I can see the ones that will change in red... but not some easy way to just show the ones that are changing out of the long list.
#2 2018-06-05 17:39
Re: Only show files with names that match rename conditions
You can use these context menu options:
  • Clear - Clear Not Changed (Ctrl+D)
  • Mark - Mark Only Changed
#3 2018-06-05 17:56
Carphunter
thanks
is there a way to set those options as presets so i don't have to do it on every load?
#4 2018-06-05 18:35
Those context menu options can't be activated automatically.
However, you could use Filter Settings to avoid adding files to ReNamer which match certain criteria. These settings can be saved in presets.
