#1 2018-07-08 19:38
Xbon
Moving into parent folders
Been a while since ive used ReNamer
But i thought it would help me... so before i purchase it
I have my cd collection ripped on a couple of 8tb hdd`s
On one hardrive is my cdlp and on another is my compilations.
problem is i have 40,000 cd`s and i need help in achieving this.
On my cdlp drive i have folders like
King - 2018 - Remixes & Rarities Cd 1
King - 2018 - Remixes & Rarities Cd 2
I would like to move them into a parent folder like this
King - 2018 - Remixes & Rarities (2CD)
And on my comp hdd i have pretty much the same like this
Celebration 2000 - (545066-2) Cd 1
Celebration 2000 - (545066-2) Cd 2
I would love them in a parent folder
Celebration 2000 - (545066-2) - (COMP) - (2CD)
Ive tried a few ideas and the results were not what i wanted, is this possible, and thanks.
#2 2018-07-08 21:26
Re: Moving into parent folders
If I understood it correctly, your biggest problem is how to sort your albums into parent folders.
Ok, here is a Regular Expression rule which will do just that:
Replace expression "\A(.*?)\s*\bCD\s*\d+\Z" with "$1\\$0" (skip extension)
Here is an example of input and output folder paths:
C:\Temp\Celebration 2000 - (545066-2) Cd 1     -->>  C:\Temp\Celebration 2000 - (545066-2)\Celebration 2000 - (545066-2) Cd 1
C:\Temp\Celebration 2000 - (545066-2) Cd 2     -->>  C:\Temp\Celebration 2000 - (545066-2)\Celebration 2000 - (545066-2) Cd 2
C:\Temp\King - 2018 - Remixes & Rarities Cd 1  -->>  C:\Temp\King - 2018 - Remixes & Rarities\King - 2018 - Remixes & Rarities Cd 1
C:\Temp\King - 2018 - Remixes & Rarities Cd 2  -->>  C:\Temp\King - 2018 - Remixes & Rarities\King - 2018 - Remixes & Rarities Cd 2
C:\Temp\Test Folder                            -->>  C:\Temp\Test Folder
All folders which have a suffix "CD 1", "CD 2", "CD 3", and so on, are moved to a common parent folder. Other folders are ignored, e.g. "Test Folder".
This should get you moving on that front.
The next step would be appending a suffix "(2CD)", "(3CD)", and so on, to the parent folders. This will probably require a use of Pascal Script rule, but first, let us know how you get on with the parent folders.
#3 2018-07-09 06:42
Xbon
That worked great, just purchased full version, thanks
Cal
#4 2018-07-09 08:59
Excellent!
Let us know if you need further help on this topic.
#5 2018-07-09 09:08
Xbon
I think i'm ok, thanks once again.
