#1 2019-06-28 18:00
BLJ
help for rename file (cut ,paste,copy...move)
Hello ,
1) thanks x the software , it's very very very helpfull ! big_smile
2) English it'snt my language , so please forgive me for bad
sentence or error sad
actually i have a little problem (Idea) with a few file i want to rename :
the file name structure is  :
original name:
New name:
ther is a function , scrypt o similar  for automacally  " move" the name before "-Page_XX" after "-Page_XX"  ?
[i don't know any programing language sad]
It's possible introduce this as a function ?
something like :
<< move text before "$$input$$" after "$$unput$$" >> ??
thanks
#2 2019-06-29 02:26
Re: help for rename file (cut ,paste,copy...move)
You can use the Rearrange rule for swapping around parts of the filename based on a delimiter.
Rearrange: Split by exact pattern of delimiters "-", New pattern "$2 - $1" (skip extension)
There are several other rules which can achieve similar effect, see the documentation for more details:
http://www.den4b.com/wiki/ReNamer:Rules
#3 2019-07-01 14:23
BLJ
1000 thanks !
start experimenting this solution.
