#1 2019-09-07 15:58
jeffli
Two problems about rearrange ENG+CHN filename with regex rule?
Problem 1
I get a problem when I try to rearrange "Chinese中文.txt"(English characters + Chinese characters file name) to “中文Chinese.txt” with regex rule in ReNamer 7.1.0, the regex rule is:
Expression: ([a-zA-Z]+)([\u4E00-\u9FA5]+)
Replace:$2$1
//Expression: ([a-zA-Z]+)([\u4E00-\u9FA5]+) works well in https://regex101.com/r/RmoAP8/1 as ECMAScript.
It shows the error file name like this:
eChines中文.txt  //Error, I want "中文Chinese.txt".
How to rearrange a file name combined with English characters and Chinese characters?
Problem 2
Does ReNamer 7.1.0 support Unicode scripts "\p{han}" in regex rule?
If it does, I can use "([\p{han}]+)" instead of "([\u4E00-\u9FA5]+)".
Jeff
#2 2019-09-07 19:57
Re: Two problems about rearrange ENG+CHN filename with regex rule?
Problem 1
The regular expressions engine in ReNamer uses a slightly different syntax for defining Unicode character codes.
For example, instead of "\u1234" you need to write "\x{1234}".
See this for the reference:
http://www.den4b.com/wiki/ReNamer:Regul … _sequences
In your case, the expression should be: ([a-zA-Z]+)([\x{4E00}-\x{9FA5}]+)
Problem 2
The Unicode properties based classes like "\p{han}" are not supported at this moment.
#3 2019-09-08 00:25
jeffli
Problem 1
Problem 2
It works, thank you very much. I am very sorry I didn't even notice it when this problem happens.
RegEx pattern	matches
\xnn            Character represented by the hex code nn
\x{nnnn}        two bytes char with hex code nnnn (Unicode)
Jeff
#4 2021-11-13 13:55
Bingman
Very appreciate, this solves my confusion:P
