#1 2020-11-19 19:59
Antonio
Subtract 1 from the number at the end of filename
Hello Den4b, what about subtract 1 value to the end of the files:
The ones that exist like "IMG-20150818-WA0000.Jpg" they can became "IMG-20150818-WA0000-01.Jpg" With "-01" at the end.
Thanks.
PS. Nice job on ReNamer. Perhaps you should change "Pascal Script" with "Python Script".
Potentially relevant thread: How to increment number in the filename
#2 2020-11-20 00:01
Re: Subtract 1 from the number at the end of filename
Your statement and your example seem to contradict each other. Can you clarify if you want to append a number at the end of filenames, or you want to actually modify the existing numbers in the filename by decrementing them by 1 ?
It would also help if you provide a complete list of desired new names for your example filenames.
#3 2020-11-21 01:57
Antonio
Hello, I would like to decrement 1 to the end of the files before the extention.
The think is that I copy twice pictures from my smartphone from the app Whatsapp and I don't know why but the second copy increment the name of the files by one. Now I want to be sure that they are equal to be able to delete the dupes.
I see that exists files that ends in 00 that ones I want to differentiate since when I decrement one when is 01 will go to 00 and became with the same file name .
See the size of the file is right, but the name is increment by one:
Thanks.
#4 2020-11-24 00:10
It sounds like you are using a wrong tool. I would recommend using a duplicate file finder tool to eliminate your duplicate files, and then, maybe, clean up the remaining filenames if there is still a need.
A quick check for binary-duplicate files can even be performed by ReNamer by substituting the new name with an hash of the file (like MD5 or SHA1).
> Insert "C:\Temp\:Hash_SHA1:" replacing current name
After adding this rule you will get warnings about binary-duplicate files, due to identical hashes, if there are any. You could then chose to delete or move the duplicate files.
#5 2020-11-24 18:01
Antonio
den4b, thank you for the help.
I search for SHP1 using this tool and then renaming some files with your tool.
Thanks.
