#1 2020-12-16 03:48
Whimsical
Add tags to files
Hi, sorry if this was already asked, I tried to find a solution in the forum, but gave up.
I would like to add "tags" to files. I tried to use the "details view" in Windows Explorer but some files (pdf for example) don't have the option to add a tag.
Can anyone give me a hint where I could add tags in the ReNamer? I am sure there must be a way, but I am no coding whizz and my logical brain side is rather challenged smile
Thank you already very much!
Whimsical
#2 2020-12-16 17:38
Re: Add tags to files
You can apply a wide range of meta tags via Insert and Replace rules, among other ways.
Simply click on the "Insert Meta Tag" button.
See also:
https://www.den4b.com/wiki/ReNamer:Meta_Tags
