#1 2021-01-26 09:39
swanx
renamer file from clipboard
you can rename a file list from a list on my clipboard?
or also: you can rename a file list from txt file?
i have 2 list of various file on 2 different folder: i want copy all name files from one folder to other file on another folder...
#2 2021-01-27 11:11
Re: renamer file from clipboard
Yes, you can paste a list of files/folders via the clipboard.
Navigate to the Main Menu » File » Paste Files or use the Ctrl+Shift+V shortcut in ReNamer.
Yes, you can import a list of paths from a text file.
See the Export menu above the files table. There you will find an option labeled "Import files from text-list or play-list".
#3 2021-01-27 14:54
swanx
oh yes! work fine.
tanxs for your reply.
