#1 2021-05-21 14:04
LadyBug
How do I do this: 001 - XY -> 001. XY
Hello! I am real blond, dumb and non-english speaker so by patient, pls. Thank you smile <3
I have this:  001 - Kapitola 1 and need this: 001. Kapitola 1
... is it possible? And how?
Also I have this: https://ibb.co/k2DLSRW
everything is ok, I have 01 bla bla -> I want -> 01. ok -> and I got -> 1. ok ... but No 01. ok. Where is the problem, pls? Zero is missing, but the rule is there?
Thank you! smile
#2 2021-05-21 14:33
LadyBug
Re: How do I do this: 001 - XY -> 001. XY
Oh and I forgot: *I have this:  001 - Kapitola 1 and need this: 001. Kapitola 1
and ofcourse I need ->  001 - Kapitola 1 and need this: 001. Kapitola 1
                                   002 - Kapitola 2 and need this: 002. Kapitola 2. etc.
#3 2021-05-23 04:28
yapues
The the Replace rule
Find " - "  (without the quotes)
Replace ". "  (without the quotes)
Occurrences = All
Skip extension
#4 2021-05-23 14:42
LadyBug
Hello, dear! I'm very thankful to you for helping me with this. I really appreciate it.
I tried it, but I have a new problem big_smile .. I have:  001 - Kapitola 1 and after your help (<3) .. I have: 001 . Kapitola 1. It is better, but I need
001. Kapitola 1  (no 001 . Kapitola 1)  I need the dot closer to 001. if u understand my english. I am pretty girl, but totally stupid. I am sorry big_smile
Thank you!
#5 2021-05-23 23:56
eR@SeR
Hello LadyBug,
Solution by yapues should work as per the given examples. If you don't provide which rules you added, we can't help you much. For more information on how to work in ReNamer see wiki page.
I created RegEx rule which might help for some cases...
1) Regular Expressions: Replace expression "(\d+)\s*-\s*" with "$1. " (skip extension)
001 - Kapitola 1
001  -Kapitola 1
001-   Kapitola 1
001-Kapitola 1
To:
001. Kapitola 1
001. Kapitola 1
001. Kapitola 1
001. Kapitola 1
Next time try to provide examples in this form as it is more readable.
You have "Export to Clipboard" option in Rules area - right-click and then you can paste it here in case you want to show what rules you have added.
#6 2021-05-25 12:14
LadyBug
Hi eR@SeR! Thank you very much. smile I am completely lost, but u helped me. I will try and learn. Again - thank you, it is nice smile and you are a good person. Wish you the best.
(And thank you also the creator of this great software.).
