#1 2022-01-16 13:40
Lauraq
Selectively change the case of filename parts
Hi smile
Is it possible rename:
11 - Il Vero AMORE (feat. zampa, rido mc, gomez)
I want
11 - Il vero amore (Feat. Zampa, Rido Mc, Gomez)
Another example
06 - Barre aSTRALi Celesti (feat. blodi B, naghe, Zeus one)
to
06 - Barre astrali celesti (Feat. Blodi B, Naghe, Zeus One)
in practice I would like the first capital letter of everything contained in the parenthesis and, in the title of the song, only the first capital letter
Thanks smile
#2 2022-01-16 22:04
Re: Selectively change the case of filename parts
If I'll find some free time I will reuse that
>> https://www.den4b.com/forum/viewtopic.p … 215#p12215
example and adjust the regex for you. (now its too late for me and I am afraid my brain is not fit enough)
#3 2022-01-16 23:13
Lauraq
Yes...is a my question, I remember it but this is a new situation sad
Don't worry, help me when you want/have time and without haste  smile
#4 2022-01-17 12:00
Try that...
TRY:
1) Case: Capitalize every word (skip extension)
2) Regular Expressions: Replace expression "^(.+?[a-z])(.+)\(" with "\U$1\L$2(" (skip extension)
Explanation:
(.+?[a-z]) >> give me all, non-greedy, till one char from group of A-Z, and store in group 1 >>>06 - B<<<
(.+)\( >> give me next all till one open parenthesis, and store in group 2 >>>arre aSTRALi Celesti (<<<
Replace:
\U$1 >> give me content of group 1 and change all chars to upper case >>>06 - B<<<
\L$2( >> give me content of group 2 and change all chars to lower case >>>arre astrali celesti (<<<
\L     Convert all characters to lowercase.
\l     Convert only the first character to lowercase (that's a lower case L).
\U     Convert all characters to uppercase.
\u     Convert only the first character to uppercase. > do not work here, because it works on the first sign, not necessary on the first char.
Note: The "\U" for "$1" is not really need here, as it is already uppercase, but used just for an example in case somebody need it for his/her issue.
See our RegEx reference for more details
>> http://www.den4b.com/wiki/ReNamer:Regul … ipulations
#5 2022-01-17 18:08
Lauraq
thanks smile but there is a problem when the songs is named without "(feat"
for example
06 - Une chrononaute à paris
is renamed in
06 - Une Chrononaute À Paris
sad
And another problem, the script rename all world in "(" and I want only when there is "(Feat" or "(feat"
for example, it rename
08 - Let me sleep beside you (alternative mix, 2021 remaster)
in
08 - Let me sleep beside you (Alternative Mix, 2021 Remaster)
Thanks for your help...and patience smile
#6 2022-01-17 18:45
That's why it's important to well design the question and provide every possible source as example, because the answer base on that.
I will take a look...
#7 2022-01-17 19:02
Lauraq
thanks smile
#8 2022-01-18 18:15
So only problem is that other files which doesn't have "(feat" in name are renamed too?
06 - Barre aSTRALi Celesti (feat. blodi B, naghe, Zeus one).ext
07 - Barre aSTRALi Celesti (Feat. blodi B, naghe, Zeus one) - Kopie.ext
08 - Une chrononaute à paris.ext
09 - Let me sleep beside you (alternative mix, 2021 remaster).ext
06 - Barre astrali celesti (Feat. Blodi B, Naghe, Zeus One).ext
07 - Barre astrali celesti (Feat. Blodi B, Naghe, Zeus One) - Kopie.ext
Solution:
1) add your files
2) right click context menu on files and select "Mark by Mask" and enter *(feat*
((see >> https://www.den4b.com/wiki/ReNamer:File … rk_submenu ))
3) add both rules from above
4) rename
#9 2022-01-18 18:48
Lauraq
sad no, the problem is that even year titles are capitalized, for example
05 - Wanna Be MYSELF
and I want
05 - Wanna be myself
#10 2022-01-19 17:38
and I want
Sorry, I don't understand.
1) "year titles" ? But not in that example, no?
2) "05 - Wanna Be MYSELF" is not touched , if you only select file name like *(feat* , see my last post above.
