#1 2022-11-19 00:08
abdnlad
re naming photos
Hi
I have this problem, I simply don't understand how to use ReNamer.
I have 10's 000 of photos collected over the years friends family etc.
The date of them is not a problem as I filed them when i took them, but what I do require is for all of them to be re-numbered from 1-300, so they are easier broken down and shared with family. Some files contain over 1000 photos
Thanks in advance
Pete
#2 2022-11-19 18:59
Re: re naming photos
Can you provide some examples of input and desired output filenames?
See the Quick Guide to understand how to use ReNamer.
#3 2022-11-19 21:01
abdnlad
Hi
Some are named and some are not, I just want to strip all the names and replace with numbers from 01-300
Is this possible and how to do it?
#4 2022-11-20 19:01
You can use the Serialize rule to achieve that.
> Index starts: 1
> Repeat: 1
> Step: 1
> Pad with zeros to length: 3
> Where: Replace current name
#5 2022-11-21 09:56
abdnlad
Hi
Thanks for reply
I cant strip the names, just renumber the photos, cant find "where replace current name"
#6 2022-11-21 18:01
jogiwer
To build up a complete name add a "Delete"-rule as first rule. If you mark the checkbox "Delete current name" all the following rules work on an empty name (with skip extensions the extension itself keeps untouched).
#7 2022-11-23 07:29
abdnlad
Hi
I have tried the delete rule on a file of 2000+ photos and only 5 names were removed. These are not copyright or anything just family photos. I followed the instructions, but I still don’t know where I am going wrong
#8 2022-11-24 14:43
Hi Pete, there are some misunderstanding or false information:
Read your posts again:
is for all of them to be re-numbered from 1-300.
abdnlad wrote:
Hi
--- 10's 000 of photos
--- re-numbered from 1-300 ? me guess, you mean folders?
--- Some files contain over 1000 photos ? you mean "folders contain" ?
--- Some are named and some are not ? you have files without a name?
Please sit down, think, and then explain again what you want to do.
Maybe, take a picture of your situation and show us?
You can also start a CMD.exe console window,
browse to the top main folder of your issue,
use the DOS command:
TREE /F >"C:\Temp\aaaa.txt"
clean up the lines in "aaaa.txt" to keep only a few and post that here.
I could imagine you want to rename folders?
-"""cant find "where replace current name""""
> read the whole post of den4b again.
#9 2022-11-24 19:09
abdnlad
The photos are already in folders, the name of the folders will not change, some are holiday folders by country and date Christmas etc
What I do want is the contents to change, but they are all mixed up with other people renaming them or adding other family members photos.
I want to rename all the photos from 01 to 300 then start again if more photos are in file from 01 to 300
#10 2022-11-24 20:00
For
try the Serialize rule as den4b shows above and additionally use there "Reset every: 300"
Reset every    Reset index to the initial value after processing this many files.
