#1 2023-09-14 19:38
djneilsfla
Deleting the second parenthesized phrase
First, thank you in advance to whoever took the time.  I DID in fact try to find it in index but didn't see one specific to my question.  It's simple.  I would like to put batch of files into the renamer and remove information I don't need from song tags.  Example.
Nicki Minaj - Super Freaky Girl (Roman Remix) (Dirty Extended Remix)
I want to get rid of the second parenthesized phrase.   (Dirty Extended Remix)
Ultimately, I would LIKE to be able to keep the first parenthesized phrase.  (Roman Remix)
Not sure how to accomplish that.  And thank you again for the assistance.  It is GREATLY appreciated
#2 2023-09-14 20:29
Re: Deleting the second parenthesized phrase
You'll need to use the Regular Expressions rule for this task.
Expression:
(\(.*\))(.*?)\s*\(.*?\)
Replace:
$1$2
This will remove the last parenthesized segment, when there are at least two parenthesized segments.
#3 2024-01-31 15:24
Lauraq
very useful, could you also tell us how to eliminate the first parenthesized segment and how to reverse the two parenthesized segment?
Thank you smile
