#1 2007-06-24 20:42
justsmile
ReNamer 4.65: EXIF_Time
Hello Denis!
First, thanks a lot for your great program!! smile
But what happened to the EXIF_Time Tag? I tried to follow the instructions as in
http://www.den4b.com/forum/viewtopic.php?id=90
but EXIF_Time is not working/available in the list (version 4.65)
If I insert
:EXIF_Date:-:EXIF_Time:
I will get
"25-03-2007 16.32.26-:EXIF_TIME:"
and not
"2007-03-25-16.32.26"
Please check this!
Thanks!
#2 2007-06-25 08:29
Re: ReNamer 4.65: EXIF_Time
In some previous versions of ReNamer, time and date tags were separated, so where the date/time format settings. From ReNamer 4.20 (8 Nov 2006), date/time tags were united, so EXIF_Time no longer exists. EXIF_Date stands for both date and time. To see the most recent list of supported meta tags, open "Insert" rule, and find "Insert Meta Tag" button.
Just remove "-:EXIF_Time:" from your insert rule. To change the date/time format, look into the Settings.
Good luck smile
