#1 2024-04-22 13:25
Starroma
Why Renamer don't add files which exceed MAX_PATH limit?
Does Renamer have a limit on the maximum allowed length of folder and file names? If not, why I can't add files exceeding MAX_PATH limit to the program?
#2 2024-04-22 17:11
Re: Why Renamer don't add files which exceed MAX_PATH limit?
It's more like the Windows operating system has the MAX_PATH limit.
ReNamer can handle long paths but there is a catch, that is to use the "long path" specification be prefixing paths with "\\?\".
More information on the wiki: https://www.den4b.com/wiki/ReNamer:Long_paths
